dj-rix
    351
    Leicester
4140 profile views
dj-rix's Achievements
Member (4/8)
  1. dj-rix
    Tial MVS springs
    As above, what have you got, close to leicester preferred
  2. Bump
  3. Glanza drivers mirror in silver
  4. Have a Defi egt gauge, where should I fit the probe, on the manifold? Which runner? Or the down pipe?
  5. Some idiot fitted an FCD right next to the Ecu and removed it leaving the wires in a mess, blobs of solder and electrical tape. Any way to test that the wires are ok and not giving a dodgy signal/ voltage to the map sensor?
  6. What about timing, set as 4e marks, 10deg at 750rpm?
  7. I've already got all the parts bud, just need to know how to make it work
  8. Diagnostics didn't show anything
  9. Plug look white so clearly running lean, there is a big hole in the flexi, would this cause it to run lean?
  10. Standard fuel regulator and injectors?
  11. has this been done? whats max boost it can safely run?
  12. As above New or used in perfect condition Ct9
  13. Wouldn't the engine light be on if there was a fault?
  14. Timing is bang on 10deg at 750 rpm in diagnostic mode Is there a way to test the TPS?
  15. Tried unplugging the lambda, it didn't affect it. With foot flat down it feels like the cars holding back, feels like it's in 5th gear when it's actually in 1st, turbo spools really slowly and takes a while to get to 3k, when it gets to 3k it's fine and boosts fine.
