Hello, I'm currently on a conversion progress (right handed ep82 to left handed ep8*) so I can run a turbo starlet on my country... Got the engine runnning recently after being stored a few years, runs OK, heats up a bit...but the main problem is I've got the radiator fan running whenever ignition is on and a high idle....don't have the cluster plugged in yet (mk2 loom and mk1 cluster, needs rewire). Sounds like idle is at about 1500 -1800 rpm... I know when you remove the A/C you need to bridge some conector to stop, at least, the rad fan, but since I didn't remove it myself, I don't know wich one it is. Can someone help me with this? Some photos maybe? If interested, its a mk1 Auto ECU, mk2 loom, turned to manual...removed all extras including P/S and A/C...these parts will be for sale if someone wants them.. They were in working order when the car was stripped 3-4 years ago. < Thank you
