glanzalee123
    11
    shrewsbury
1290 profile views
glanzalee123's Achievements
  1. It was up for 5k since it has had alot of money spent on it manual conversion with oem lsd box bran new spec clutch map to suit manual box an lots more £££ it did say 6k ono but its not for sale now so admin this can be locked was a moment of madness!!
  2. Thanks guys I appreciate it 😁
  3. It sure needed it 😁 thanks mate
  4. Thanks mate , an yes it is I give it what it needed an that was a manual box 😁
  5. Year:1996 Model:Toyota starlet glanza v Tax:N/A MOT:31st July 2016(but willing to give it a full ticket) Mileage:140.000(mix of km an mph) Description: Gauging intrest in my glanza v as she is now up for sale as need a bigger car for family commutes but I'm in no rush to get rid an wont except stupid offers! So please no swapz/part x CASH sale only! If your looking for a track toy/weekend car this is the car for you with a massive 283bhl she goes alrite an shows alot of big boys up ????. Please do not expect a bran new car she is now 20 years old so expect wear an tear, there has been no expense spared on this car with every bit of paper work to prove ???? Tuning developments stage 2 fully forged engine- Wossner 74.5mm Low Compression Piston Kit with Rings and Pins Scat 4EFTE Forged Conrod Kit with ARP Rod Bolts Athena 1.2mm Uprated Metal Headgasket ARP 2000 Uprated Headbolt Kit inc New Washers Genuine Toyota Full Gasket Kit Genuine Toyota Oil Pump Kit OEM Water Pump Kit OEM Cambelt Kit inc Idler & Tensioner ACL Main Bearing Kit ACL Big End Bearing Kit ACL Thrust Washer Kit Fully Machined and Polished 4EFTE Bottom End Fully Stripped, Cleaned and Rebuilt 4EFTE Cylinder Head to Standard Spec Block, Head and Rocker Cover Cleaned and Painted in our Tuning Developments Black and Silver Theme 460cc Injectors J performance FMIC WEPR external wastegated manifold/decat and screamer pipe Tial external wastegate Recon TD TDO4 turbo race tech water lines & TD oil line TD low temp thermostat Magnecore HT leads dean RW developments battery clamp & oil cap twin core civic radiator with fan- toyota coolant sard FPR with gauge halfords battery magnetic sump plug dean RW developments full custom cat back exhaust system with a unreel angle back box ID workz heat slam pannel TD fuel pump Purple and blue hosing i.e radiator pipes/power steering pipes TD brake and power steering covers powerflex engine mounts all 3 NGK heat range 7 spark plugs OEM fuel filter OEM dizzy cap and rotor arm pcv Drivetrain Bran new spec stage 3 paddle clutch Oem LSD gearbox Chasis BC racing coilovers EBC grooved discs and yellow pads OEM front and rear 3 point brace C pillar bar brace hells braided brake lines all around OEM x2 hand brake cables 15 rota grid Vs with parada spec 2 tyres 195/50/15 FULL hunter alignment Interior OEM fishnet recaro interior- rear seats/door cards/front seats OMP style steering wheel sound proofing inside EMB ECU kit Blitz dual boost controller Exterior Genuine JAM front lip/99 spec bumper & grille OEM rear lip/bumper OEM duck tail spoiler ID workz live sports spoiler-fresh paint OEM side skirts OEM bonnet 99 Spec facelift rear lights Like NEW OEM toyota glanza headlights 3years old tilted number plate bracket/ X2 new number plates 8000k HIDS hi/low civic rad has custom brackets made up not cable tie Price:£6000 ono Pictures: Contact Details:pm on here or 07783268586
  6. Year:1996 Model:Toyota starlet glanza v Tax:N/A Mot:31st July 2016 Millage:140000 Engine Tuning developments stage 2 fully forged engine Wossner 74.5mm Low Compression Piston Kit with Rings and Pins Scat 4EFTE Forged Conrod Kit with ARP Rod Bolts Athena 1.2mm Uprated Metal Headgasket ARP 2000 Uprated Headbolt Kit inc New Washers Genuine Toyota Full Gasket Kit Genuine Toyota Oil Pump Kit OEM Water Pump Kit OEM Cambelt Kit inc Idler & Tensioner ACL Main Bearing Kit ACL Big End Bearing Kit ACL Thrust Washer Kit Fully Machined and Polished 4EFTE Bottom End Fully Stripped, Cleaned and Rebuilt 4EFTE Cylinder Head to Standard Spec Block, Head and Rocker Cover Cleaned and Painted in our Tuning Developments Black and Silver Theme 460cc Injectors J performance FMIC WEPR external wastegated manifold/decat and screamer pipe Tial external wastegate Recon TD TDO4 turbo race tech water lines & TD oil line TD low temp thermostat Magnecore HT leads dean RW developments battery clamp & oil cap twin core civic radiator with fan- toyota coolant sard FPR with gauge halfords battery magnetic sump plug dean RW developments full custom cat back exhaust system with a unreel angle back box ID workz heat slam pannel TD fuel pump Purple and blue hosing i.e radiator pipes/power steering pipes TD brake and power steering covers powerflex engine mount NGK heat range 7 spark plugs OEM fuel filter OEM dizzy cap and rotor arm pcv Drivetrain Bran new spec stage 3 paddle clutch Oem LSD gearbox Chasis BC racing coilovers EBC grooved discs and yellow pads OEM front and rear 3 point brace C pillar bar brace hells braided brake lines all around OEM x2 hand brake cables 15 rota grid Vs with parada spec 2 tyres 195/50/15 FULL hunter alignment Interior OEM fishnet recaro interior- rear seats/door cards/front seats OMP style steering wheel sound proofing inside EMB ECU kit Blitz dual boost controller Exterior Genuine JAM front lip/99 spec bumper & grille- fresh paint OEM rear lip/bumper-fresh paint OEM duck tail spoiler ID workz live sports spoiler-fresh paint scuttle panel- fresh paint OEM side skirts OEM bonnet 99 Spec facelift rear lights NEW OEM toyota glanza headlights tilted number plate bracket/ X2 new number plates 8000k HIDS hi/low civic rad has custom brackets made up not cable tie Price : £6000 Ono Contact: Either pm on here or 07783268586
