Jim.c
    39
    U.K.
1503 profile views
Jim.c's Achievements
  1. Nice cheers for the heads up. I have just put my 5efhe in my ep91 last week the wiring was a mission but all works as it should. Put my 4e conversion flywheel on torqued all the bolts up fitted the clutch put the box on and found out the 5e dust guard plate does not have as many bolt holes as a 4e so had to take it all back to bits and swap the plates over so I could fit my g6 box lesson learned lol
  2. It is for sprint racing where you are racing in classes so when you are limited to 1.6NA in my class every little helps and just sticking a turbo on it is not an option. But no if I wanted just to make it faster for the road a 4efte would be the way to go of 5efte
  3. Don't suppose you know which would be better on a 5efhe out of the standard non acis manifold or the tubular corolla manifold ported to match the 5efhe throttle body do you
  4. What is the advantage of bike carbs over injection
  5. Thanks that is a very detailed and helpful response.i will find you on istagram. How comes you used 4e pistons instaed of 5efhe high comp pistons. I take it the silver top head flows better than the 5e. Was it a big pain to modify to fit thanks for your help
  6. Ha how did I know that was coming. I can't or I won't be able to use it in the class I want to race in next year
  7. hi has anyone tuned a 5efhe and had it on a dyno. struggeling to find any reliable information on what works the best for them thanks
  8. would a ep91 galanza adapter wiring harness for emanage blue work on a ep91 4efe or are there a difference in pins thanKs
  9. Thanks much appreciated
  10. Hi does any one no if the glanza rear trailing arm bush fit a ep91 NA starlet thanks
  11. sounds good I have got a lightweight flywheel and a glanza clutch already fitted on it so that won't be a problem. Thanks for your help think I may go ahead and get a box then cheers
  12. Yeah looks good. Would you say the box made much difference
  13. Yeah would make sense for a glanza to have longer gear ratio for higher power but on my little NA sprint car it is all about acceleration. There must be someone who has one on a NA. Cheers for all the advice people
  14. Ok did you use the g6 shifter cables of the original starlet ones. What size wheels do you have on it just out if intrest.i am building it for sprint racing so top speed doesn't really bother me just trying to get the gear ratio best for acceleration. Would you say it gets to the top end in fourth and fifth easier as my NA struggles a bit in that respect thanks for your help
  15. Any one fitted one to a NA ep91 starlet. And did it make much difference to the acceleration thanks
