Flappjak
    7
    Chesterfield
958 profile views
Flappjak's Achievements
  1. My indicator, high beam and rear fog lights work as well as my Speedo but my fuel and temp gauge doesn't work as well as the battery light and oil light doesn't show up when the ignition gets turned on? I've checked the fuses as well as the tail light fuse but nothing. Any help?
  2. Yes the ignition was on, the high beam and rear fogs are the only lights that come on the dash or the Indicator's falsh with the hazards pressed iirc
  3. That's what I was thinking for the Indicator's but then what about the battery light and engine warning light
  4. I've got a 97 sportif and it's been off the road for a few months and I came to start it last night put jumper cables on to charge the battery but I have no indicators but hazards work, and there's no lights on the dash when the ignition is turned on. Has anyone had this problem before? High beam and fog light are the only ones that come on
  5. Yes the k11 micra the only difference is the panhard rod is at the back of the axle instead of in front
  6. You can get the micra adjustable ones (I used to run one on my old micra) but it was just a thought since there’s a few people who custom make them for £70 inch postage but like you said might as well get one that’s been made for the starlet
  7. Right I was wondering if a micra panhard rod would fit? I know that when you lower a starlet you need a panhard rod to correct the axle movement, it was the same setup as my old micra and since micra panhard rods are about £50 I was wondering if they’d fit?
