Sam259
    18
    Battle
Sam259's Achievements
  1. Making big dog power. Looking awesome
  2. Has anyone got a fully stripped rear and had it all painted?
  3. ive got both engines and want to build a decent forged fairly high power engine and just want to know what peoples preferences are between the two.
  4. what oil make and type are people using?
  5. thanks
  6. does anyone know if you can buy these still?
  7. Sam259
    map sensors
    Ok thanks appreciate it
  8. Sam259
    map sensors
    probably stupid question but here it goes anyway, im running a td04 and emanage ultimate which has a 3bar map sensor and an apexi avcr boost controller which also has map sensor, so do i run the standard map sensor as well as both the others??
  9. The gauge and sensor were supplied as a kit there doesn’t seem to be an exhaust leak no the sensor had always been plugged in.
  10. Pretty certain I have
  11. It was originally doing the same on the ct9 but now I’ve got td04 on it with decat and blitz front mount, so I’ve got fpr with gauge and running 3 bar fuel and I put the 430cc injectors in but still the same so I changed them back for standards for the minute and I’m on the stock ecu, I do have an emanage ultimate to go in but I wanted to sort the problem first before adding that. The sensor is at the end of down pipe and the gauge is prosport And the sensor was new appreciate it thanks
  12. As far as I’m aware it hasn’t been mapped. Its a Bosch sensor and can’t remember what gauge
  13. Just fitted td04 and fitted a wideband and on idle it’s reading 11.2 running rich and then when you throttle it, it’s going up past 20 going really lean. Any ideas??
  14. Would 220bhp be reasonable on the td04?
  15. What size injectors are people running with td04?
