Heath
Member-
18 -
												Auckland, NZ
Heath's Achievements
	Hey, I have a link G4+ ECU so picked up the speed signal off that, had to change a resistor on the cluster circuit board to allow for the voltage difference. I’m sure someone else could show you how to get the speed. When I get some time I’ll do a write up with some photos with what I did. Heath
	Hi all, just an update on the above. Have my car all up and running. Swapped in my 5efhte had a mate wire in a Link G4+ ECU got it dyno’d and puts out 230hp atw @ 18psi. Got some meister R coilovers and levin 2 pot brakes. Rewired to get the glanza v dash in. Got through a few teething issues and using as a daily driver. Really enjoying the car atm, Heath.
	Hi everyone, just a quick one. I have an EP95 and wanted to know what is on the other side of the fuel tank to the fuel pump? Is it a transfer pump? Do they need uprating? I have a 5efhte and running a deatschwerks fuel pump. No issues so far. Thanks in advance, Heath
	Ended up getting this running, was quite a mission. Had to trace the wiring by looking at the back of the clusters.
	Hi all, I have an EP95 with a 5efhte conversion. I am wanting to fit the Glanza V gauge cluster and trying to suss out the wiring. I've done a lot of reading on this forum but not finding what I'm after, a lot of the wiring diagrams are not loading or only available through photobucket. I think I have a handle on the glanza V wiring requirements but have little information for the EP95, which I assume is the same as an EP91 4efe (non turbo). Any help would be much appreciated.
	Hi all, I have an EP95 with a 5efhte conversion. I am wanting to fit the Glanza V gauge cluster and trying to suss out the wiring. I've done a lot of reading on this forum but not finding what I'm after, a lot of the wiring diagrams are not loading or only available through photobucket. I think I have a handle on the glanza V wiring requirements but have little information for the EP95, which I assume is the same as an EP91 4efe (non turbo). Any help would be much appreciated. Thanks, Heath
	Hey guys just dropped my 5efhte into my ep95. Need to do all the fluids. What is recommended for the front diff and gearbox oils?
	Hi everyone, I’m currently swapping my 5efhte into a ep95. As part of the swap I am fitting a new aftermarket intake manifold with larger throttle body. It’s one of these common designs that you see around. Just wondering if there is any need to lengthen, replace or modify the throttle cable? Or should I be able to reuse it as is? Thanks in advance , Heath
NEWBIE NEEDS HELP AND SUPPORT FELLOW STARLET LOVERS!
Heath replied to badboy_lesta's topic in EP91 Progress Blogs
Hey guys i have a ep95 (4wd) Toyota reflet, 2 door. Been reading through this thread. My car currently has no lip spoiler and I’d like to fit the glanza to my existing boot. Can anyone please advise what’s required in fitting this? There are no connection points so is this glued in place? If so with what? And are there holes to be drilled or anything? Thanks in advance. Heath -
	Cheers
	Hi guys, on the weekend we had some vandals f*#k up my house and my ep95 front / rear windscreens. Replacement cost is pretty high for the rear windscreen ($700 nzd) and insurance won’t pay anything. Its likely cheaper for me to replace the entire bootlid from a glanza v and get the lip spoiler at the same time. I’m aware that there’s additional reverse lights, brake light and changing locks over but other than that is it a direct bolt up? Thanks in advance, Heath
	Great thanks, will check it out
	That’s great, thanks for the response. Heath
	Hi guys, been doing a bit of reading around the centre diffs and wanted to check my understanding with you. As i understand it, the viscous coupling will only transmit power to the rear wheels when there is a speed differential between the front and rear. So driving in a straight line the rear wheels rotate on their own and the coupling is not transmitting any power to the rear. The car is essentially operating as a front wheel drive. But when traction is lost on the front, the viscous coupling will transmit power to the rear. This would occur when launching. Have i got this right? Or is the coupling always transmitting power to the rear and will increase / decrease it on a front / rear speed differential? And how does this tie in with the 60/40 split? Sorry I figure this has been discussed before but I couldn’t find the right answers. Heath
	Hi guys, looking for recommendations on engine / gearbox mounts for my proposed 5efhte ep95. I’ve had issues with aftermarket mounts before being too hard and having to remove them due to excessive vibration. I also found standard too soft on my gt starlet. So looking for something in between. What’s everyone using and are they the same as ep82 / ep91 mounts? My aftermarket ones were not powerflex, not sure who made them. Cheers
