cam13T
    58
About cam13T
  • Birthday November 11
cam13T's Achievements
  1. Hi, i have a cusco master cylinder stopper and am wondering if i have the correct one. I have a glanza with ABS, and am trying to fit Pic-1, it just doesnt seem to line up- i havent had a good go at it yet but i thought it would be easier. I have done a bit of searching and i know there are 2 models, so does anybody know if Pic-1 fits on the glanza with abs? or do i need pic-2. PIC-1 PIC-2
  2. I thought so, Thanks Idrees
  3. I have a set of the late model glanza clear taillight lenses and i have some taillight units from a ep95. They will bolt up fine but as the only difference between them is that the late model ones are clear. So wont the top brake light wont be red except for the little red strip. Do the late model lights have some internal differences like a red cover inside??
  4. How do i save my sent messages? edit- Just found the box when writing a message that says 'send copy to sent items'
  5. Yes they should come off easily, there should be a little dab of glue at each end and then peel them off slowly. I would recommend getting new ones and they are not exspensive (In Aus they were $50ea = 25GBPea.) They are nice and shiny makes the roof look brand-new and are alot easier to fit then the old and they come with the double sided tape attached too.
  6. Can anyone with a glanza help me?
  7. Hi, i am building a glanza from a n/a and i have swapped the rear axel over to rear discs etc. I need to know where or what direction these 6 wires head in? They travel from the ABS unit under the steering-wheel and down under the drivers side sill cover and head towards the rear. My loom was cut half-way as i got a front-cut. I believe the twisted pairs go to the sensors on each side but unsure where the others should be correctly terminated. The abs plugs enter the floor pan in front of the rear wheels and on the vertical part infront of the rear seats. So does anyone have there glanza stripped at the moment or next time you take your sill cover off to tell me where the wires shoot off to. Thanks Thanks
  8. cam13T
    fcd ?
    Yes i 2nd that, Manifold and dump and new actuator should be on top of the list.
  9. any body here that has one of these, could you tell me where the 2 wires go to. Thanks
  10. Hi, i have a illuminated surround for the ignition barrel from a glanza and i am wondering which wires i connect it too.
  11. Yes from memory it is tucked in the passenger side of the bootlid, Wiper Control- Blue box.
  12. Yes definately try a live feed to the motor, i had a similar problem a few months ago with a crook motor. Take off door trim get a bit of 2-core twin cable jam that on your battery and test it directly on the motor.
  13. I was told it was the same as this mate.
  14. all sorted now i found a diagram. Thanks
  15. Does anyone know how to wire up a Jam FCD to a glanza V. I have four wires coming off the fcd- Red-white-Black-green. Thanks
