Item Condition: used, very good Price & Conditions: deposit taken Item Description: Here is my engine from my gt that i had built by TM-Developments two years ago. I spent alot of money having it done and it is a great little engine. I did 6 oil changes in the first 1000 miles and ran it in as it should be. Since having the engine out of the car i have had the sump off to re seal it making sure i removed absoloutly all the old sealant. Also i used brand new bolts to put the sump back on. The rocker cover has been painted and a new gasket, nuts and washers have been added. The engine has covered 8000miles give or take and the most boost i ran through it was 1 bar with a toms ecu. The spec is as follows which i have copied from the original reciept from TM: Engine stripped and thoroughly chemically cleaned. Block rebored, crosshatch honed. Forged Wiseco low comp pistons, 74.5/mm Scat forged rods. Crank Pollished Head stripped and cleaned, valves re seated, new valve stem seals New Head Bolts. New Toyota oil pump, new water pump, new cam belt and tensioner kit, new oil sender switch, new thermostat. All new gaskets and oil seals. Metal head gasket 1.2 Ported head Race Spec rocker cover Pictures: Location: Tonbridge, Kent Contact Details: pm me or my number is 07917817258 Postage & Packaging / Delivery: Collection or organise your own thing
