Disco Stew
    16
Disco Stew's Achievements
  1. One of the rose joints on my rear Panhard rod is fubar, need to replace the rod, anyone know where i can get one from and if its adjustable wht it should be set to? Also im looking at getting an antilift kit, i already have an arb so wht does an antilift kit look like and where is it mounted? Any hlep would be great! Stew
  2. Great pics considering it was a point and shoot! Is that a laguna lip on the blue EP? Looks nice a subtle! Where is the location looks good!
  3. Before you spend any money check youre rear tyre pressures, if to high then it makes the back end very light and twitchy, reduce them a couple of psi or just chack what they are atm. Simple way to diagnose the problem with out spending money or a strut or rear ARB.
  4. What is the widest wheel you can fit on a glanza as i want to mod mine with a bit of euro style, some schmidt's or ronal turbos and a big drop ie coilovers! Is it possible to slam a glanza seing as they are rear beam! cheres
  5. and squeezy marmite....
  6. Im trying to find the gps reciver from my toyota double din sat nav unit which it came with from japland! Any help as to where to locate it? Cheres
  7. I did mine and helped my confidence although i passed 1st with 0 minor faults. i can get you a pass plus certificate signed by a fully qualified driving instructor for £50, so you dont have to do the extra hours, just pay £50 and he will give u a certificate to say youve passed for insurance reasons!
  8. Can anyone shed some light on how to fit an oil temp gauge, ive brought an auto gauge and the wires are like 1ft long, wht can i use to extend them and how do i fit the oil temp gauge? Regards Stew
  9. Its a glanza v so its the turbo, i think the 4fte engine im not sure, new to the starlet scene!
  10. Does anyone have a copy of the diagnostics codes for an ep91, i want to find out what my warining light means, so if i bridge the diagnostics connectors the engine management ecu will flash and relate to some data which will help me find out what is rong with my car! Please help! Thanks Stew
  11. I have a jasma exhuast on my glanza v, is a cat back i think from looking under the car, what is next for my exhaust system i.e what section should i replace next as i want it slightly louder but more free flowing as such as im worried im limiting flow with standard exhuast up to the cat! Any help much appreciated! Stew
  12. Yes it does apparently but so far all ive got it 2 do is open/close and tilt, i think the text is a warning or security thing!
  13. Hi im Stew and own a EP91 import, has jasma cat back, apexi filter, hks adj actuator, white and blue bbs rims which i cant anme as i dont no but they are the 1st set ive seen like it! Im loving boost and still own my civic EK3 which i will sell eventually! Anyway here are some pics, im undecided if i should remove the rear mirror tints as i think it makes it look like a van, should i or will it detract from the jdm'nes! Also got these other projects on the go, My vitra fatboy which im preping to be a off road monster: And my mini which im going to vtec eventually but alot of rust needs sorting before hand! Cheres for looking and i hope to meet some of u at a few meets soon! Stew
  14. HI im new to the ep91 and last night i was driving along, had i bit of a blast in 4th gear to overtake then this light came on: I no the picture isnt very good but it was whilst i was driving, so i took it easy after that, got home turned the car off the on again and the light went out. Should i worry about this or is it just a temporary thing! Any help much appreciated! Regards Stew
  15. Hi ive recently brought a Glanva v jdm import and it came with the origional double din head unit. But it dosent want to work, it opens and closes perfectly but there is a constant piece of jap text on the screen which i dont no what it means. Does anyone know what i can do to correct this or get it working? Is it any use to someone else ie can i sell it? if so how much 4? Rgards Stew
