crazy gt
    42
Everything posted by crazy gt
  1. Ok mate cheers i will check them out now Thanks again mate
  2. Any one as I have to finish this tonight
  3. hi can any one help i was looking at a set of rota svn 16" in blue with polish lip on ebay but there in the usa and post is abit on the picey side does any one know were in the uk i can get a set of these from thanks
  4. Hi can any one help I am fit hid-d with boost controller I have connected gauge to controller the the other wires coming out the gauge but on them there is an orange wire ( pressure signal in ) it tell you to connect to hdi sbc d but were??
  5. The only thing is been looking at it and the pipe that comes with is to sort for were fit to my boost controller is I would have to reroute all of it that would be a pain will the ones I have not be ok then
  6. Hi I am just wiring last bits on my car and a mate has come to help but he has just said about the pipe I am useing on my actuator he thinks they won't work propely I have used slicone brether pipe I used on my dump valve not the pipe you get with actuator but the pipe that come with it is a lot thicker which is the one he said use what pipes should I use ? :harhar:
  7. crazy gt
    Toms Ecu
    Cool thanks for the help mate :harhar:
  8. crazy gt
    Toms Ecu
    hi i am just about to put a toms ecu in my gt but was just wondering if any one is useing one as i see people talking about jam and blitz but not the toms is it as good better ect or is there not much diffants i am runnig rx7 intercooler blitz bov hid-d boost contrlloer hks atuator decat new mainfold and am goning to set at 1bar
  9. cool thank god for that just put back together and i need to ajust it that clip that goes on the arm is a bi**h lost 2 trying to fit it were it conectes to the arm on the turbo it is bent in so nearly imposable to get to thanks again for the help mate :harhar:
  10. can anone tell me if i can just reless the lock nut and turn the arm it self to ajust it or do i have to take if off as i got my old one got hold of the arm and that can be turned freely
  11. crazy gt
    Ecu
    cheers guys i have cancaled toytunning part i will order decat just had new egine and new plug were just fittted i will check what was used thanks again
  12. crazy gt
    Ecu
    hi can any one help i have just got an toms ecu just need to know if i need any thing else as a few people have said i need a high temp spark plug and leads,fpr and upgraded fuel pump i want to run 1 bar on standard internals and stock ct9 my car spec at the moment is standard boost car has blitz ner spec ,stainless Mani ,blitz air filler and bov ,rx7 top mount intercooler ,1.3 rad cap ,boost controller o and it will also will have an adjustable actuator soon had to order another one as i ordered one for toytunning
  13. hi i have got one of these and i have not had a problem yet only been on for about a mouth but i have showed this to a few friends and my dad who has degrees metal and fabrication and welding and they all say that it is surprisingly well made and the brace should be fine. the weld look good well the did on mine the only thing i would say is it would be better if they had smoothed the welds on the inside you would probably get a little better flow
  14. hi have you still got any of the large stickers left if you have I will have one just let me know details so I can pay Thanks crazy
  15. crazy gt
    what next
    hi can any one help? i have had the car for a mounth now(ep82 gt) it has blitz nur spec cat back and blitz ss bov and sus blitz filter i want more power what whould be the best next step? any help would be great thanks crazy
  16. Thanks I will look in to that it was just bit strange that boost drop was after I fitted new bov
  17. hi i have a gt ep82 and it was running 0.6 bar fitted a ss blitz bov had a bit of a problem setting it up think i got working now but it know runs just under 0.5 bar put old one back on and still run just under 0.5 bar any help would be good and could u tell me what sort of rpm the car needs to be at to sound the bov when in nuetral mine between 5000 and 6000 not sore this is right i had a gt4 and that was about 2500 to 3000. tanks crazy
