Graeme
    236
About Graeme
  • Birthday 06/17/1989
  • Website URL
    http://
    Elgin
Graeme's Achievements
Member (4/8)
  1. All intact mate
  2. Timing wasn't the issue, had it checked all was good. I threw a new set of plugs in it today even thought the old ones seemed fine, car is working again, although i cant work out why just happy it is.
  3. already checked it, every things lining up as it should. I've had each plug out and tested in the lead lying on the block and they all seem to be getting a good enough spark.
  4. Could this be an injector issue, just pulled plugs again and they're fairly wet...
  5. changed dizzy cap as it was looking a bit tired when i split it, timing checked, battery charged as it was a bit dead. Car turning over easily but still wont fire, where would i get an ignitor from if it turns out to be that when i take it off to check continuity, toyota? could it be anything else as this is really starting to annoy me now.
  6. being a bit dense here but what part is that?
  7. I'll see if i can borrow one from someone tomorrow.
  8. Im sure the carbon deposits are caused by the car running slightly rich and the fuel by attempting to start the car over again. My friend just didnt torque up enough seemed good when i got it back and worked for about 1 week, heat + vibrations worked loose, freak accident. Car isnt going anywhere so you needn't worry about other road users... Any tips on checking if timing is correct without getting it towed to a garage?
  9. Dizzy was marked before it was taken off last time so just aligned back so the marks match up. Is there a how-2 on properly setting up?
  10. As topic title really. Been having intermittent issues with starting for a month or so now, got the cause down to shagged fuel pump. Fitted a new walbro unit and all was good, started first turn of the key. The other night I was driving and I suddenly lost all power, this was due to the distributer working its way loose as my friend didnt tighten it fully when i had it off to check it on his car to see if his one was knackered. This morning went to start the car, fired up first time, drove 5 ft then car died, felt like when you run out of petrol but the car has fuel and is getting fuel to the rail as I took the fuel line off and fuel comes out when you crank the car. I took the spark plugs out one by one and tested in the HT lead, all seem to be getting a spark although it seems weak (spark was orange/yellow, been told it should be blue/white for strong spark), the spark plugs were black and soaked in fuel. Is there an easy way to check the EFI fuse without just fitting a new one? Anything else that could be the problem, I am really stumped with this. Cheers
  11. Was just about to post this exact topic. I suspected fuel pump as well but this confirms. I love this site, so much info!
  12. Wallace performance tuned my mates S14a, he did a good job from what he told me. Dont know anyone who got a EP mapped there though, i am considering taking mine when i get a EMU
  13. Cool, if you still have it in a week or 2 I'll take it
  14. Looking for a 96 spec kph dial face to replace my cheap MPH one that bleeds light everywhere... Would also be interested in a complete 98 spec dial cluster (red needles yo!) Again would have to have kph face. Not in a desperate rush for either of theses.
