steve
    4
steve's Achievements
  1. any body driving a starlet gt is not a coffin doger ?????????????????????????????????????????????????????
  2. hi to all ep82 ep91glanza owners just received my brandnew je pistons from america they are just fantastic these were bought from ( topend performance ) And the cost only (( £410)) all inclusive to my front door any bore size any compression ratio that you require all thats required is a phone call or email and a paypal account. there are lots of options on piston surface finish and type of rings required the £410 was for standard je forged pistons pins and rings.this company is excelent three weeks for custom pistons from date of order and if you need any info all you need do is email there customer service is great.... http://www.topendperformance.com/ mailto:topend@racetep.com all the best steve.
  3. no stud pcd wrong spacing
  4. look under your bonnet valve clearances should be on a sticker this is what you need to do you need a good set of feeler gauges set cam lobs one at a time measure clearance ie if 0.20mm feeler blade will slide in but 0.23mm will not you then know that your clearance is 0.21mm or0.22mm write this down all shims come in 0.05mm increments after you have measured all your valves you need to remove your shims on the under side you will find the shim size if not you will need a metric micrometer to measure the shim... So if a valve clearance should be 0.30 and your measured clearance is 0.22mm and your shim measures 2.35mm you need to round down in 0.05 increments this would mean that you need a 2.25mm shim for this valve... if valve clearance is to large you round up... a cheap way to get a collection of shims is go to a scrap yard most toyota engines use the same diameter shims if you by your shims from the dealer first see if you can swop any shims around you will usually only have to buy one or two shims hope this helps.. steve w
