ep91_glanza
    171
    newcastle
ep91_glanza's Achievements
  1. can someone help???
  2. i took the vaccum pipe off the actuator and it is now wanting to boost loads so could it be a dodgy actuator or?????cheers
  3. ive checked everything nd thats the only thing that it might be,but even if i alter the boost would i not see a change ? Cheers
  4. i think the hotpipe that goes on the turbo is leaking but i didnt think that would lose so much boost would it??
  5. Ive just fitted my engine andBefore it was set at 1.0 bar but now it wont go past .5 bar ive tried turning boost up but dosnt make any difference.can any of yous help??? Cheers karl
  6. I looked at the torque specs on tgtt and it said 1st 22nm 2nd 44nm the 3rd had 90o is that degree turn or 90 nm thanks for help in advance
  7. Ive just fitted a new engine and wondering if i need it setup on a rolling road again?
  8. Just ive done an engine rebuild and got a bee r rev limiter and didnt know if i wanted to take a chance
  9. Hi i just want some opinions on the rev limiters and if they are safe to use if used only on the strip?? Anyone using them at the minute??Cheers karl
  10. Ive done a bearing does that mean that ive got to get a different size bearing or what?? Help much appriciatado!!! Lol
  11. i recently had a loud knocking noise coming from my engine so i took the engine out and basically took it all apart and found out that i span one of my conrod bearings and it totally worn the bearing down and has worn the little lip/groove on the crank shaft where the conrod bearing sits and there is signs of wear on the conrod, im just wondering if i just replace the bearings or what i need some advice cheers.if pics would be easier i can get them up tmrw
  12. Very impressed with the delivery and service off enzo it was only a pcv valve but no matter what it is hes got it or can get it to ya within a few days....cheers matey.karl
  13. Hi does anyone wanna do a swap for some rota rewinds with no kerb marks a little sign of etching on the chrome and has four new tyres 15z
  14. i think it is just normal gear oil because it hasnt got the viscosity on the bottle its just honda mtf for manual transmission
