starletgt troy
Member-
30 -
About starletgt troy
- Birthday 09/14/1989
Maidstone
starletgt troy's Achievements
Thought would post this as ive searched and can not find anything. Is there anyone running an apexi safc mapped. If so what was your bhp readings and what supporting mods have you got, boost settings and rrfpr pressure settings etc? cheers
From experience if the bottom end has gne that bad u will have to get the crank skimmed, possibly even another crank. Tools you will need is: socket set metric spanner set metric ( if you can get ratchet ones all the better) screw driver set pliars wire cutters m9 spline tool for head bolts deglazing tool for the bores or use 1200 sand paper piston ring clamp puller for the bottom pulley and a impact gun depending how tight bottom pulley is valve spring clamp valve grinding tool and paste torque wrench torque angle guage tip ex- to mark where bolts come from and position of parts u remove i think thats all the tools, depending on the extent u want to rebuild the engine and the spec uprated gaskets and stuff is up to you but at a minimum parts wise you will need full engine gasket kit silicon sealant for the sump piston rings new head bolts ( you dont have to change these but for peice of mind i would) big end bearings new conrods ( depending on condition of old ones if they are scratch or marked where the bearing is replace) cambelt kit These are not essential but depending on age and conditon water pump oil pump oil pressure switch get the head skimmed if all the rods are from older car get em balanced and checked hope this helps just some tips for when you do the work pre oil all parts before refitting also depending where you are doing it u can jus leave the block in the car and do it that way all preference and tools available. and possibly new belts
Sounds rather cheap but am always looking for cheaper options of modifying my car but reliably. Does any one know any other toyota cars that have bigger injectors that will fit a 4efte? Been looking at ones from supras which have the equivelent flow rate as sard ones. And possibly mr2 turbo ones? Any help appreciated
Turbo Deristriction 1st And 2nd
starletgt troy replied to madmax_926's topic in Intake, Turbo & Exhaust
Im not entirely sure what power gains to expect just from the emanage, but it will stop the fuel cut. But the boost creep (where the boost slightly increases through the rev range) will still occur. I found this on another thread for what you need to acheive 200 bhp reliably hopefully this will give you some sort of guidance what you will require for your goal this is from Toby at toy tuning and i found it really helpful: This is what we recommend for a good 200hp setup with brakes and chassis to match â?¢ Hybrid CT9 â?¢ Free Flow Mild Steel Manifold â?¢ Decat â?¢ Cat Back system 2.5inch The car is now expelling gases more efficiently. â?¢ Relocated Air Filter to front bumper â?¢ Heat Reflective tape for Inlet Track â?¢ Raise the Rear of the Bonnet with washers â?¢ Front Mounted Intercooler (wrap throttle body side pipes with heat reflective material) â?¢ Uprated Thermostat â?¢ Rad Cap Car is now breathing more efficiently â?¢ Consider better radiator and breather/header tank if planning on track days Car is now cooling more efficiently â?¢ New Spark Plugs (consider colder grades) â?¢ New HT leads â?¢ Inspect Dizzy/Rotor Ignition system now works â?¢ Uprated Fuel Pump â?¢ Fuel Pressure Regulator Kit â?¢ Engine Management/Piggy Back/Fuel Controller (depends how far you want to go) â?¢ Rolling Road Session Car now fuelling adequately â?¢ Uprated clutch with flywheel is poss â?¢ Quickshift Kit â?¢ LSD if poss Car can now handle power and you can shift quicker This should net you around 180bhp - 200bhp on 18 psi max. This then leaves the brakes and chassis which will need to be sorted to cope with the power. I would recommend at a min: â?¢ Uprated Front Disks â?¢ Uprated Pads â?¢ New OEM Rear Pads â?¢ Braided Brake Lines â?¢ Cusco BMCS â?¢ Dot 5.1 Toyota Fluid (bleed dry and refill) You can now stop! â?¢ Coilovers / Fixed height shocks with springs â?¢ Front and Rear Strut Braces â?¢ Panhard Rod â?¢ Lower Arm Bar â?¢ Anitlift kit â?¢ Check and replace worn bushes â?¢ Good tires Power to ground greatly improved. Thatâ??s a basic list of what we recommend, obviously there are many more parts that will net you a good handling car that can stop with power to match but that should give you a good idea on where to take her pending needs. This doesn't take into account basic servicing which is a must, make the most out of what you have no point adding mods until the car is up to scratch -
Porting the waste gate is simple, if you know how to remove the turbo that is. I done mine myself and cost me at the most £5 and that was buying the grinding stones from halfords. Im not sure where but there is a tutorial or thread on how to do this if i find it ill post the link for you Best of luck with it tho -
good stuff cant wait to get it all set up now cheers
Ohh i see i understand now :-) Thanks for your help has helped alot Do you know of what sort of power you can acheive with this setup?
Ohh i understand now, would i be correct in thinking to run at 1 or 1.1 bar you would have to have a rrfpr to add more fuel than need and then use the safc to cut the amount of fuel injected through lower boost areas? and remain the same for the areas above the fuel cut?? Cheers
After alot of thought and confusion i am still unsure about this and would appreciated some knowledgable advice. Thinking it would be simple confused myself about the order of wiring, i have an apexi safc II and a greddy fcd. They both require cutting the pressure signal to the ecu but which would go 1st coming from the presure signal and which one second closest to ECU plug. After doing some research one person said have the fcd after the safc so it receives an un-touched signal. Does the fcd not just weaken the signal from the sensor making the ECU think the boost is lower than it is therefore making the safc pointless?? The second one obviously with the fcd first followed by the safc. Surely the fcd will weaken the signal to avoid fuel cut then the safc sending a stronger signal to the ECU to put more fueling in result in the ECU operating fuel cut?? Help please so confused
Bhp Day At Lyden Hill Race Circuit
starletgt troy replied to 200bhp starlet's topic in South East Region
Ill be there went last year was awsome Sadly last year had no break pads so was no track time for me -
owww never mind looks like a ebc will be next on my list then. cheers for your help though is much appreciated. Troy
Okay i shall give it a go. I thought was something to do with the intercooler as it was fine before i changed it from the stock. Is there any other means of reducing it before i splash out on a ebc??
I have no boost controller just an adjustable hks actautor, the turbo is made from a ct9-b, with the waste gate ported and the compressor housing and wheel of a speed vision hybrid. Troy
No this is on a hybrid ct9, do you have any recommendations for size intercooler to run 1 bar? Cheers
Any one got any information or advice they would like to share??
