Louis
    261
About Louis
  • Birthday 08/26/1990
  • Website URL
    http://
    Derbyshire
Louis's Achievements
Member (4/8)
  1. Has anyone got the pipe which goes from the standard air intake to the recirc dump valve? Little 90 degree 30mm wide pipe? Needed ASAP Text me as I'm very rarely on here. 07738331115 Louis
  2. As title states, EP82 rear gearbox powerflex mount bush required. HAS TO BE SPLIT TYPE this is for easier fitting. BUSH + PIN ONLY Needed ASAP PM me or message 07738331115 Louis
  3. Perfect, just what I wanted to hear!!! Thanks
  4. So could i go to any shop that sells rattle can paint and get '199 silver' ??
  5. hmmmm i don't know about silver yet, only just got it. Cheers daniel_g your a true gentleman
  6. Hi people, i need to spray the headlight surrounds on the GT, i need the paint code, where abouts is it located on the body? or if someone could tell me from the pic? Cheers, Louis
  7. Okay cheers guys, I will see how much it is to get them refurbed and weigh up my options thanks once again
  8. Okay the EP82 has failed its MOT on the hand brake, ive wapped up the cables after looking that the mechanisms are free but this didnt cure the issue, i think its internal. So i require 2 new rear calipers or a rebuild service whats best? cheers, Louis
  9. As title states, drivers side seat belt reel complete wanted in good working order with no tears. Mine has failed MOT due to fraying requires replacement. Required ASAP 07738331115 Louis
  10. Sounds pretty epic!!! looks like you got some serious speed there at the end!
  11. Did it make a big difference fitting the glanza top mount and FM air filter?
  12. Possibly lose wastegate penny if its when returning to idle mine used to rattle when on over run traveling down hills it when i noticed it more
  13. Download "Simpsons: tapped out" and you wont have a life then onwards!!
  14. Just needs a new battery, and a regular drive to keep the charge up Edit: pretty sure this is my old car?
  15. I suppose people should'nt expect it to be the next forza as it clearly is'nt, its a dumbed down forza with the need for speed and test drive unlimited genre
