Rhys249
    92
    Pontypridd
Rhys249's Achievements
  1. Where is my money mate
  2. Has anybody hered from mau5 ???? He still owes me £110 for a manifod that i never got seemed like a tidy guy that wa having a few problems with sending the manifold, draged it out for longer than the 45 days i had to get the money back through paypal (my own fault, i werent in a rush to get it and he seemed honest enough) the number i've got is -07906833094 if anyone else wantst try it He's been ignorin me for the last fe days, if any one has another contact number/email address/facebook page for him then let me know, i'll give him a chance to send the money back before I reverse the credit card transaction looks like hes messed a few people about on here
  3. Rhys249
    Rhys249
    Not a problem mate, been a pleasre to deal with you
  4. I couldnt see any reason it wouldnt work, think i'll have a go if i dont find one soon
  5. Hi all, i've been looking for an externaly gated ct9 mani for a while but havent really had much joy and i cant afford a brand new one. So, i was thinking is there any way you could modify a non external mani to make a 38mm flange type waste gate fit, i'm looking to get a WEPR or a zisco mani, has this been done before or is there any reason that this wouldnt work. or if anyone has an externaly gated CT9 mani kickin about, let me know, Cheers guys
  6. I'm having the same sort of problem in my 82, the revs drop quite low if I have the lights, whipers, heaters ect on, and it judders a bit when pulling off, works fine when i'm driving but the revs drop quite fast between gear changes
  7. Thats his way of saying its got a blow off valve fitted RRRRRRRRRRR TESS !
  8. Glad its not just me then lol, got a rattle that comes from the back somewhere and one that comes from the front somewhere, me and the missis cant agree whatside its coming from. allso got a wierd sort of rubbing/rattling sound that started when the snow came, seems to rattle when the spedo needle bounces, from about 50 onwards lol seems to get worse when its cold think it couldbe something to do with the speedo cable
  9. not sure what ecu it is, just a plain silver box that sits under the standars one definatley not got a fcd fitted to it. will be going in to the garage soon to have a new clutch fitted and maybe my td04 kit, so i'll get them to do a compression test, i just dont want to fit the td04 kit to it if its not running as it should be
  10. it will boost to 1 bar but i keep it below 0.7, i dont drive it past that ever, i know about the restrictions in the manifold and i know the damage it can cause so i never let it go past 0.7
  11. yes but i never drive it at 1 bar, only ever been there once or twice, usualy keep it below 0.7
  12. hi guys, having a few problems with my GT, over the last few months its not been feeling as good to drive as it did when i 1st had it, its had new plugs, leads, oil and oil filter wich helped a little bit but now it just feels the same again, the problems i'm having are - juddering when pulling off, allmost feels like the car looses all its power and nearly stalls idle speed is all to shit, some times on a warm start up idles at 500 prm really late boost, comes on full boost at about 4500 rpm on a ct9 with air filter re location, standard mani and decat and i've been told that its running ritch (only by my mate who knows a small amount) the mods i have are - fmic air filter relocated to the grill decat and ss exhaust hks bov uprated fuel pump i hav allso noticed the car has an aftermarket ecu left on it by the preveous owner, it dosent hit fuel cut till 1.0 bar and goes well past the 180kmh on the clock i was going to try an unplug the ecu and see if i can run it on the standard one ?????? any info would be great cheers guys !
  13. There was no pin, its hard ton explain but it was a small bit on the inside of the comp housing that you couldnt get a tool in to, the exhaust housing side had nothing atall on it tho anyway its all rotated and seems to be ok, wont be on there long hopefully lol
  14. only just realised there was a pic lol, yea that bit.ity seems to stop the wastegate lining up with the mani, i can see wat i was doin wront tho, i had the smaller bit going in to the mani instead on sealing the valve
