Carl.
    344
About Carl.
  • Birthday 02/09/1990
    South Yorkshire
Carl.'s Achievements
Member (4/8)
  1. buying flowers for my mummys birthday lol Remove my plate from title please.
  2. happy birthday
  3. Border line Barnsley/Roth. Classed as Barnsley but I'm a Rotherham boy through and through ;)
  4. Happy birthday pal!!!
  5. Havent really thought too much about it, maybe 3700
  6. I'm selling mine pal, just not had chance to get her advertised yet. Pretty much standard, have a gander at my build thread if your interested, got 71,000 on clock http://www.ukstarletclub.com/forums/index....c=27865&hl=
  7. you can if you use the bit where it says <center.></center.>
  8. i presume your putting a filter on the end of this piping.. sounds like a good homemade cold air feed anyway mate ;)
  9. It was spring that had gone like I thought. Can't understand why though, it's only been sat in garage for about 11 month. Anyway hks adjustable is back on now. Cheers lads.
  10. But at the same time stopping the turbo pulling down on the mani, but a braced decat/standard cat does this anyway
  11. That's bracing the turbo to stop it putting pressure on the oil feed.
  12. Ive started putting my v back standard because im selling up soon, so im wanting to get boost running at 0.8 bar like when i bought it. anyways i whipped my hks adjustable actuator off and put standard one back on, but its only boosting up to 0.3bar now this tells me the spring has had it and wastegate is being allowed to be forced open too early, but what i cant get my head around is that it was totally fine before it was taken off so am i right in saying it should in theory be ok less than a year on, sat in a box? another thing is ive connected it up to the same rubber pipes that came with the hks actuator, one of which has a small brass restrictor in...... would that make any difference? any ideas/comments i cant be bothered with putting the hks one back on then messing about setting boost
  13. ^ x2, your decat wont be causing this, will be actuator.
  14. bump
