BajanHitman
    29
About BajanHitman
  • Birthday 11/21/1983
    Barbados
BajanHitman's Achievements
  1. Water meth been working for a while now. Currently running around 22psi on pump and meth. I installed a nissan knock sensor yesterday and turned on knock control in the ecu. I would like to know what is the knock frequency stock knock sensors listen for and how many volts count as knock
  2. Does one need to notch the block like with SCAT rods with these Max Speeding ones?
  3. Hi I am getting the same problem. Changed Oil pump, changed pressure relief valve, check strainer every thing seems fine but yet no oil pressure at all. When I took off the pump i didnt even see oil on it at all, both are new pumps. Any Ideas. I had started the car and still nothing.
  4. Up to now it snot hooked up hoping to do so soon
  5. http://www.ukstarletowners.com/topic/60581-glanza-v-from-the-caribbeantime-slips-added-first-drag-meet/ More pics and stuff there
  6. Did 13.2 in the quater. A friend of mine his fully built 4efte did 13.1 he put down rubber all of his second gear luanch. I didnt partake in that event. My favourite pic of all time https://www.facebook.com/photo.php?v=10152212346184112 Car would probably do a way better time with a better driver. My launch is horrendous.
  7. Thanks for the reply guys. Nope unfotrutnately still have not gotten a complete map as yet. But we now have a working two wheel dyno which I hope to go on soon. Would like to rebuild a stock motor and keep my car for strictly going to work but it will have some pep to it. Hopefully use a dif shell for drag events. OH snap i forgot to mention I took part in an actual quarter mile speed test. Unfortunately the car was not tuned to its full extent as the set up changed and we had no time to do anything. The clutch was also a problem it would not disengage and engage properly then it started to slip after the very first run. Gonna go grab some pics
  8. That is a full track race car it houses a Honda K20 car is almost all fiberglass
  9. My first Dragg event. It wasnt as easy as I thought it would be. The lights need getting used to. And I was never a good launcher lol. Car was tuned the friday night and I got to practice moving off the morning at 7. Burst a tyre I need way more seat time. Car was tuned the friday night on half shell half 109. Up to now I cant tell you what psi it was on or what afr cause I had no time to even look that side. My fastest time was 8.8 vs Manimal and that was due to me loosening up a lil. At one point my gear selector cable came off I had to pull off and place it back on. Was so nervous i could not remember what a 4 looked like even put on the 3 backwards My fastest time slip. Left the line at 8200rpm 2nd Gear no feathering Think its quite plain to see my reaction time and launch technique needs loads of work.
  10. The civic won. I have to get sued to the light tree and practice my launches. The civic is a fully built motor. 2.1L with a huge turbo running 16psi at the moment. Second gear launch at 6500rpm
  11. My first event actually using a Tree system. i sucked at first. I still do. more pics to come but i did my best time againt my friend's civic this is an eith of a mile My car woud not put down the power had to launch car in second gear high rpm
  12. We have no choice but to fabricate or order off ebay. Parts here are expensive. My intercooler and intercooler piping came from EBAY Godspeed. 109 and 78us 3inch double 90degree ehxuast pipe came form ATPturbo.com Fuel pump came from ebay i think as well or a source in the US along with the magnaflow exhasut. Flex pipe cost 60bds on ebay but here it cost 265bds. Made sure i ordered the ic piping with the bends i needed which was as many 90s as possible or U bends. Finally got my timing set back correct today. Set it yesterday using the timing guard but forgot i have on the 4e timing cover which differs from the 5e so I had to manually find TDC and mark it on the guarge then mark ten degrees on the guard and lock the AEM timing wizard on that mark. car feels normal again. Getting slight sputter upstairs thinking its noise interference with my wiring have to check that out. Racing is 16th FEB need 380 to race dunno if i will get it but I want the car ready for sure. Thanks for the support guys.
  13. Made buy a machinest here in Barbados. Anthony Stoute he LOVES starlets
