nzEP85
    22
  • Website URL
    http://
    Hamilton, New Zealand
nzEP85's Achievements
  1. Sadly have to pull out Enzo, car is going to my mum in september. Doubt she'll need/want an rear ARB.
  2. Nice EP95, first carat one ive seen. Different, but equally cool.
  3. Update, ran a new pb last night. Pretty sure this is the limit of a factory EP85 with full interior. 17.7 nzEP85 (EP85 4E N/A 60-70hp) February 2011
  4. Sweet, no big deal if springs dont go ahead. Was actually planning on getting ZOOM's from japan in the future, shipping will most likely be less etc.
  5. Keen on both, any clearence issues expected for the 4WD exhaust?
  6. Update! Got my 17 17.87 nzEP85 (EP85 4E N/A 60-70hp) December 2010
  7. Haven't had a problem with the viscous coupling since replacing it, don't imagine I ever will, its just replacing a balanced part with a smaller balanced part, weight has nothing to do with it. Yeah the 5 door versions are ugly, would have much preferred a 3 door but managed to pick this up for an unbelievable price considering the condition and kms.
  8. Got a set of genuine TOM's C2 wheels from one of the starlet central members that I managed to pick up for next to nothing. Was after a specific size (185/55R14) as I was after a low sidewall and it also helped to keep the speedo accurate. After doing a bit of browsing around the local tyre shops, I settled for a set of GT radial Champiro GT. Was originally after the Champiro GTX but found out they was recently discontinued. PS. This made me laugh More recently ive had the boot resprayed and am looking at an alarm. Still tossing up whether or not to lower it and go 4E-FTE, not sure how far I want to take this car.
  9. Took the car to the dyno for lol's, and found out the viscous coupling had split. So after some wallet lightening I got myself a brand new EP95 one. Then went to a friends to fit the drive-shaft. Some of you may have seen this post on tgtt First things first, car was jacked up so the wheels could spin freely. Managed to get a decent look at the old shaft, note the huge amount of fluid sprayed on the underside. So took it out and laid it next to the new EP95 one. A few things that were slightly different became apparent. Firstly the mount points for the exhaust hanger thing are on opposite sides, not a huge deal as the factory exhaust is fine without it. Old New Secondly the lengths are also slightly different, also not a problem as the mounts have room for the bolts to slide. The major difference however is the flange on the transfer case side. The holes were out a few mm's So after thinking about it for a while, we decided to see if we could swap the flanges around. If you look carefully at the photo two back, you'll notice the special 'deformed' nut. In order to get this off you need to either, stick a small flat screwdriver down the hole (hard), or grind some of the top corner where the hole is to make it bigger (what we did) Then its just the simple step of putting the old flange on, which bolts straight on. And putting it back in the car. Big thanks to Fatman/Greg for helping with the install and pretty much figuring out how to make it work
  10. Thought id chuck my cars thread up here, pretty much copied from Starlet Central so sorry if the grammer is a bit fail. Heres some photos the previous owner took. Brought it off a lovely old lady who used if for daily driving to the city, till she started taking the bus to save petrol/parking. Comes with the mighty 4E-FE and C50F 4WD box Everything is stock standard, apart from the prerequisite fluffy seat covers and battery. It also came with the factory owners manual, full service history and was serviced every 2000kms :shock: ;). Was stoked to find it fully optioned with factory power windows, air con, power steering, factory toyota cd/tape unit and mud-flaps . Doesn't help in the weight department though
  11. Nice 85, massively jealous you guys have an abundance of 'S' spec variants. Highest spec EP85 here that ive seen is an X limited
  12. Anyone know if EP82 GT front pads will fit an EP85? Been told by various internet sources the front brakes are the same but haven't been able to confirm.
  13. Out of interest has anyone opened up the rear diff and had a look at the head? Just wondering what the size of the crownwheel/ring gear is, and whether some sort of lsd can be put in. My guess is a 5.6" similar to the X code diffs in the KP60
  14. Nah sorry don't have a spare. Probably better to get one from yahoo japan as I would probably keep the spare box, there relatively rare here too.
  15. Yep both 2.277:1 Wouldn't matter too much if they weren't, viscous coupling takes up the difference
