joshhayat
    6
    Nelson, Lancs
joshhayat's Achievements
  1. Ok great will give him a pm
  2. Hi could you please confirm what turbo is this, I bought it a while ago and the seller told me is a TD04 off an evo. The turbo has a bit of shaft play, who would you recommend to take it to and would it be worth it. Once repaired what sort of power output should I expext. Thanks in advance
  3. yep got a ct9 on a aftermarket manifold. Will a braided one fit on to the ct9 and where can i get one? Thanks for the help guys.
  4. Hi help needed please I notice i small oil leak on my turbo oil feed/drain pipe coming from the turbo. I've replaced the washer this weekend but it made the leak worse. I made sure that every thing lined up proper and tightened all the bolts up, but still leaking. Any advice would be much appreciated. Thanks Josh
  5. Hello can anyone recommend a head gasket kit and timing belt for a starlet gt turbo ep82
