Dicky-Art
    25
    South Lakes
Dicky-Art's Achievements
  1. Runs perfect! Cheers Dangee
  2. Finally got it bolted up
  3. Cheers pal but payed for one 2 weeks back.
  4. getting to 2 weeks now Socks! Where's this cable?
  5. Well can't get the bugger fitted! 3 full days trying and stripping more bits off to give more manoeuvrability! Just borrowed a hoist but still no joy! :sad: :sad:
  6. Socks...PM sent, received, replied!
  7. Posted to Ulverston LA12 9NP
  8. Speedo cable wanted - single piece as below
  9. The threads were loose and it unscrewed easy! But the parts A & B are still solid, can't even move with stillies and molegrips! Left soaking overnight. If still stuck will need to remove from car and get in the vise.
  10. Just got to remove the broken bit now!
  11. Hope the replacement gearbox is ok!
  12. ooops! didn't want to do that did I? But it's now disconnected.
  13. Good thinking batman!
  14. Can't get the speedo cable off the gearbox help needed please! Read that the cable sheath should be held and the metal sleeve should turn. Does A turn independent of B? Or does A+B turn independent of the cable going through it? Noticed that A has a hole into it just above the larger diameter of B.
  15. OK cheers, noticed there weren't any a couple of years back but I had trims on. Lowered and black steelies now!
