ash bash
    13
About ash bash
  • Birthday 05/04/1983
    tunbridge wells
ash bash's Achievements
  1. wasnt trying cxxt em off just wondered if ne 1 had similar issue
  2. i should say its the little bits that piss me off n the response the garage is 80 mile from me costing me 30quid ago if i cant bring car back im stuck and costing more i gota pay someone bring me home and get bak agen n i cant work as dont have car so even more lose im bringing it back monday dave i justing seeing what others thought and could advize me on what to do
  3. reply bout powersteering leak was we dont stock them washers headgasket reply was no oil wells at front. so y am i wipeing oil away from it? not holding heat i was told to check thermostate y me when i payed for them to do job if front stub axle was replaced and bearings surely my tracking should av been checked n corrected
  4. yep they just come up with crap
  5. recently had forged engine build by tm devopements idle revs all over place doesnt hold heat whilst driving when i got home power steering hoses leaking looks like headgasket leaking as im wipeing down front of block n head every week i had to put my air filter on myself when collecting car as they couldnt trackings out killed my tyres on 80mile journey its not even run in yet. heres a list of what they done n charge forged engine £1950 fitted £300 fuel pump £75 fuel reg £75 race spec rocker cover £130 paddle clutch £295 cv joint £65 stub axle £92 wheel bearing £53 engine oil £25 gearbox oil £15 labour £200 sundries £20 alt belt £10 plugs £28 fuel £7 recovery £125
  6. wel fingers crossed ul get it bak from police n not claim repair it just window n barrel add some security 2 it
  7. certifaate comes with alarm but has to be signed by qualifed person thats fitted it and some other crap i got an auto watch fitted 2mine
  8. dude did you take it lol put a switch on live wire to fuel pump hidden so cant be found its more safer than alarm immobiliser because no fukas starting engine unless they knew where switch is
  9. pole wud of been used 2 break window n snap your ignition barrel chances r they had gloves on theyd obviously been watchin 4 a while bad times always a good idea to put manual cut off on fuel pump no fuka taking your car unless got a low loada
  10. idile sensor timeing or needing remap maybe
  11. turn boost up to a bar keep revs above 3500rpm you should sit on his arse i was running my ep82 at 1.2bar with front mount intercoola hks actuator screamer down pipe blitz blow off blitz air filter mounted in grill s14 200 running stage 2 he reckoned he had 240bhp i sat on his tail on half mile straight.
  12. well the starlets are drag slags i only had frnt mount intercooler and air filter coming from grill and i was beatin celica gt4s great fun now I've had engine forged still running standard turbo n ecu and running in so borin
  13. looking good i have screamer down pipe with front exit set up box exits thro o s front bumper 170 quid may consider swap 07563165735
