mechiel
    10
mechiel's Achievements
  1. is the tps exactly the same on both GT and EP91? I'm using a GT engine now, but would like to put in the EP91 wiring. Do I need to change the TPS?
  2. About 90 degree celcius. I'm using a 10w40.
  3. hey mates, what may be the cause of it when the engine running hot, my pressure only 0.5 bar on my greddy oil press meter. when i took out the engine oil cap, the oil is spitting out from the head
  4. just to update, can use 4age 16v valve spring on 4/5e engines. The valve springs are a lot harder than the stock 4efte valve springs.
  5. thanks mate. This is what i do currently. But i don't wish to do it everytime when I do a general oil service where I need to take out my front bumper and intercooler...
  6. thanks mate for the info... do you think the oil pump is causing the problem? pack with grease does it help?
  7. hi mates, Would like to ask the pressure relief valve on the block, what's actually his job? My oil pump doesn't pick up oil after I did a general oil change service. Browsed this link http://www.ukstarletowners.com/topic/72474-5efe-oil-pressure-problem/?hl=%2B5efe+%2Boil one of the member said the pressure relief valve was full of gasket, thus I am wondering the pressure relief valve is to used to determined whether it wants to suck how much oil? thanks mate...
  8. I am not running an oil cooler. Is just a oil filter relocator for me to easier get the oil filter changed. But what I'm in doubt is why is it at cold start it got a very good pressure but once it is getting hotter, the pressure dropped until 0 bar. The oil pressure sensor is located at the oil filter relocator which is connect with teflon of half a meter length.
  9. hi fellow mates, recently i am facing this issue... I am running a 5EFTE with an oil filter relocator. During cold start, my gauge is showing 4.5 bar, when it is getting hotter, the oil pressure drop until 0. When I open the engine oil cap, i can see oil is pumping up to the head. What may be the cause of it? engine oil quality?
