stephan777
    54
About stephan777
  • Birthday 02/28/1991
    Netherlands
    Black Glanza With Gold wheels from the Netherlands.
    http://www.ukstarletowners.com/index.php?showtopic=58440
2555 profile views
stephan777's Achievements
  1. pmed
  2. I need the info to. Please pics
  3. New setup: 293.3pk 351nm on 1.4 bar boost Full Forged Engine: Wossner Forged Piston Set 74.5mm SCAT drijfstangen ACL Full Engine Bearing Set Athena MLS Headgasket (1.4mm) ARP Headbolts Onderblok genotched/gekotterd OEM oilpump OEM waterpomp Zisco performance ramhorn uitlaatspruitstuk Zisco performance Downpipe Td04L turbo van een Subaru Impreza HKS Blow off valve TIAL 38mm externe wastegate 430cc Mazda RX8 Injectoren 255 l/ph brandstof pomp Sard verstelbare benzinedrukregelaar Tanabee full uitlaat systeem HKS Mushroom airfilter Mangnecor 8mm bougiekabels Jperformance Front Mount Intercooler Spec one 6 puck paddle Koppeling Go fast bits elektronische boostcontroller
  4. The diablo has 492hp. He wasnt expecting a very fast Starlet. The starlet losing above the 200km/h. On this video was 90km/h to 190km/h.
  5. Yes it does. I hear the beatyfull sound of the lambo and smoke comes out of the exhaust. The lambo weights around the 1600kg. The glanza 930kg.
  6. The second time he gives full trottle. Not the first time.
  7. 293hp Glanza VS Lamborgini Diablo. Filmed in the Netherlands. >https://www.youtube.com/watch?v=UphHQ37dC8Y
  8. King lead is also 2000km old. But i find the problem. The spark plugs are broken.(10.000km old) I changed them and she drives like a monster.
  9. The distributor cap and the rotor are 2000km old
  10. My car isn't working good. I have a missfire above the 1 bar of boost. New 8mm magenecor cables(2000km old) New ignition rotor(2000km old) Spark plugs(iridium's 7) are 10.000km old I changed for a test run 4 iridium 6 spark plugs and the car drives alot better. I gonna buy some new spark plugs. Which one should i buy? Iridiium 7 or iridium 8 spark plugs? My setup is: Fully forged engine with a td04l turbo on 1.3 bar of boost.
  11. Reps are good to.
  12. Wanted: aftermarket bumpers glanza. Varis, livesport, zep, cruise. Every brand!
  13. 285hp is good enough. Is 300hp possible with a td04l? Setup: 5Efte forged motor JE Piston set 5efhe conrods Stock headgasket and bolts + toyota bearings Zisco performance ramhorn Zisco performance Downpipe Td04L turbo HKS External Wastegate HKS Blow off valve Sard fuel pressure regulator Go fast bits boostcontroller Greddy emanage blue Piggyback Tanabee exhaust system HKS Mushroom airfilter Spec one 6 puck paddle clutch 360cc Injectors 255 l/ph fuel pomp JAM ECU Jperformance Front Mount Intercooler
  14. td04 is good enough
