sosolid Posted March 14, 2016 Posted March 14, 2016 So i decided im going to change the seal and plug on the camhsafts. Whats the process of changing them? Quote
candy_red Posted March 19, 2016 Posted March 19, 2016 Tough one You need to remove the belt and then the timing sprocket. Of course that means you ll also need to remove every other belt u may be using such as p/s, water pump/alternator or a/c and the plastic covers Unless its a major leak or you planning on a rebuild don't bother IMHO its not worth the hassle Quote
Avinash Trance Posted May 6, 2016 Posted May 6, 2016 I changed recently both Camshaft and Crankshaft...I can tell you its time consumin. Quote
