So I'm having a temp issue, when I start the car the temperature gauge shoots up to half way and then increases to near max when then the car has only been running for a couple of mins.
The sensor on my 98 spec glanza is a 3 pin so the temp gauge is combined with the ecu temp sensors.
I've replaced the thermostat, both sensors and the engine has a new water pump fitted.
Only thing I can think of is a possible radiator blockage? I'm using a second hand civic half rad but did flush it through before fitting and it didn't seem to have any issues!
Any idea's?
