ChrisLeeBoost Posted March 27, 2016 Posted March 27, 2016 Lads lately when I've my full lights on and I downshift a belt is squealing like mad I've checked both and my alternator one is a bit loose compared to the fan belt now when I say loose I mean it just has a small bit more up down movement than the other belt, it goes away when I just run the dips with no fogs but when all them are on it squeals like mad would it be the belt or the alternator? Sorry if it's a bit of a stupid question but I just wanna single out what it is before I go buy both Quote
Turbo Goose Posted March 27, 2016 Posted March 27, 2016 Id say tighten the alternator belt first. Mine did the same when on full beam presume its more load on the alternator so makes it squeel somehow. I loosened off the alternator tension bolt, crowbar behind alternator from underneath to prize it tight then tighten up the bolt again. Bit of a ball ache loosening and tightening the bolt as theres not much room from the top Quote
