Mitchloc Posted April 15, 2016 Share Posted April 15, 2016 Hello guys, I've recently had an issue come up with getting the starlet started, i have been away traveling for the past month and unfortunately while I was away the car was not started and was left stood still for a little over a month. When i returned as expected the battery was flat, i got jump leads on the battery to try and get it started, although i got power to the car lights, dash lights radio exccc still nothing when i turned the key. i noticed there was no light at all the immobilizer so i assume that this is the issue, i imagine there would be a fuse some where although i can not find it anywhere, Im not sure if the immobilizer come with the car from factory, it doesn't look like it so i thought there would be a fuse at some point in the wiring but i cant seem to find it anywhere.The Key doesn't not have an Immobilizer chip in the key, I have a thob which is separate to the key and has to be pushed up to the immobilizer point which is located next to the fog lights . Any ideas would be grateful, i think this is what is causing the problem just need some assistance in solving it, Thank you in advance! Quote Link to post Share on other sites
aleximport25 Posted April 15, 2016 Share Posted April 15, 2016 there will probably be a fuse in the loom for the immobiliser but that could be anywhere, try removing a few panels and trace the loom, depending on the installer it could be a can of worms my other halfs SR has a after market alarm that kept having a paddy. i ended up cutting it all out Quote Link to post Share on other sites
Bug679 Posted April 15, 2016 Share Posted April 15, 2016 had this problem before on a car the battery was so flat it wouldn't let the car start even with jump leads put in a second hand battery with some charge in it and away it went. Could be worth a try Quote Link to post Share on other sites
