speermint Posted April 23, 2016 Posted April 23, 2016 When driving my car with a little more boot, the engine management light comes on then when i turn the vehicle off and on again it goes away again. Recently started doing it when i fitted a new intercooler, but cant see how this would cause the light. Any help appreciated! Thanks in advance Quote
morgey Posted April 23, 2016 Posted April 23, 2016 Bridge te1 and e1 in the diagnostics port then turn the ignition to on. Count the flashes and it should give a number. Quote
morgey Posted April 23, 2016 Posted April 23, 2016 It will be like Flash flash flashShort pauseFlashLong pauseThat will be 31 for instance Quote
speermint Posted April 23, 2016 Author Posted April 23, 2016 124234Few morw codes than expected 😂 Quote
morgey Posted April 23, 2016 Posted April 23, 2016 12 Knock sensor42 Vehcile speed sensor34 Turbo pressure signal Quote
speermint Posted April 23, 2016 Author Posted April 23, 2016 Probably havent been wiped since the previous engine though. Im assuming 34 is cause my intercoolers too small what you reckon? Quote
morgey Posted April 23, 2016 Posted April 23, 2016 It should have reset when the battery was disconnected.Does the car hold back when the light comes on? Quote
morgey Posted April 23, 2016 Posted April 23, 2016 Just had another look at 12 could be an rpm signal issue.http://www.troublecodes.net/toyota/ Quote
speermint Posted April 23, 2016 Author Posted April 23, 2016 Nah cars exactly the same when the lights on :/ Quote
speermint Posted April 23, 2016 Author Posted April 23, 2016 Someone has fully butchered my engine wireing loom think im just going to take it to an auto electrician Quote
morgey Posted April 23, 2016 Posted April 23, 2016 Just get a new loom and swap it out for a good one Quote
speermint Posted April 23, 2016 Author Posted April 23, 2016 Will have to be a summer job as ill be up north for work, and dont know anyone up them ways to help me out Quote
