JDMGlanza Posted April 30, 2016 Posted April 30, 2016 (edited) I have wired it into my car which is a ep91 4efte and when i turn the car to on the active led goes green then orange holds for a bit and then red and then goes off anyone else had this problem or might know what it is ? Edited April 30, 2016 by JDMGlanza Quote
JDMGlanza Posted April 30, 2016 Author Posted April 30, 2016 (edited) No lol i was thinking maybe that's its i cant seem to find any info of them i tried to set it up from the manual but must have not done it right.im using the knock sensor on the water temp and the air temp for the other one if that helps Edited April 30, 2016 by JDMGlanza Quote
JDMGlanza Posted April 30, 2016 Author Posted April 30, 2016 Anyone have jumper setting and also i can't connect to the ecu ?? Quote
gorganl2000 Posted May 1, 2016 Posted May 1, 2016 http://www.ukstarletowners.com/topic/82270-emu-jumpers/?hl=%2Bjumper+%2Bsettings http://www.ukstarletowners.com/topic/73393-e-manage-ultimate/ ...scroll down to the bottom for ep91 and ep82 wiring links Quote
JDMGlanza Posted May 2, 2016 Author Posted May 2, 2016 Hey thanks for the info but it still didnt work with the jumper setting and i used that wring diagram Quote
