gaztop101 Posted May 2, 2016 Posted May 2, 2016 so, i have fitted new rear brake drums with new inner and outer bearings and also new shoes, the drivers side is fine, but the passenger side makes a rubbing sound as if catching on something, its not the shoes rubbing because i backed them right off and it still makes the sound, any clues as what it could be, it sounds like a metal scraping sound. Quote
adzy Posted May 2, 2016 Posted May 2, 2016 There's a metal lip on the backing plate that can get caught on the drum, had a similar issue with mine a while back.Is it all the time or just under braking? Quote
gaztop101 Posted May 3, 2016 Author Posted May 3, 2016 ive only noticed it while jacked up and spinning the wheel, when i drive it you can hear it a bit, cant really tell if it does it when braking Quote
