EyeKeyFun Posted May 2, 2016 Posted May 2, 2016 Hello There!Im Searching Rear Beam Mounting Bushes for my 1986er Toyota Starlet EP71They are out of Stock from Toyota. And also out of Stock on the Aftermarket. I Tried to find PU-Bushes but Powerflex only have Bushes for P8 and P9.Next thing is, that there are 2 Different Part-Numbers from Toyota. The first is: 48725-10010 (1984/10 to 1986/12)The second is: 48725-16110 (1986/12 to 1989/12)It seems that Toyota made a Facelift.Does Anyone know the Difference? Maybe Diameter? or something else???I would need the older one. (48725-10010) Car is 1986/11.Any suggestions?Where can I get Bushes??? Thanks in advance!Greetings from Austria!EyeKeyFun Quote
MR-2 Posted May 3, 2016 Posted May 3, 2016 I didn't find bushings to my 1987 EP70, so I went forward hardest way and swapping shortened and modified 1996 n/a EP91 axle.Next old EP70 axle goes for modifying, custom made bushings and agressive camber stubs. That is maybe Your destiny also, somebody have to do those for You... Quote
MR-2 Posted May 4, 2016 Posted May 4, 2016 P9 have 48,5mm (later model) and P8 have smaller. Haven't measured P7, my mate do custom bushings after I swap P9 axle. Quote
EyeKeyFun Posted May 22, 2016 Author Posted May 22, 2016 Update! I bought a complete used rear axel from a later P7 (1986/11 - 1989/12) It is in very good condition. The Bushes are also like new. :-)"Plan B" is to shape Poly-Bushes from a P9 to fit in the later P7. The inner Diameter of the newer P7 Bushes is 47mm. Thans!Greetings, EyeKeyFun Quote
