5e colin Posted May 5, 2016 Posted May 5, 2016 hey lads im on the hunt for a 60mm throttlebody that bolts strait on to the starlet manifold or guide me in the direction of which/what/where to get cheers 5e colin
J_dowsett Posted May 10, 2016 Posted May 10, 2016 60mm Throttlebody is far to big for the standard manifold, standard is 50mm.. You could probably run a 55mm one but would have to weld a plate to it then bolt the body to that. You can buy throttlebodys off eBay but I'd say it would be a lot easier just to buy like a tuning developments complete manifold with a 60mm body!!
5e colin Posted May 10, 2016 Author Posted May 10, 2016 its to go on acis manifold i wont buy ebay tbs as they tend to be from china and leak on the butterfly shaft
