Cyanidesid Posted May 7, 2016 Posted May 7, 2016 Hi guys and gals I'm new to all this so this may be a stupid question. i am currently doing a td04 conversion on my 96 ep91 and there is a pipe coming from the rocker cover to the intake manifold what's it for ? And could I take it off the mani and put it to a catch tank? Quote
5e colin Posted May 7, 2016 Posted May 7, 2016 (edited) leave as is for now as you seem to have only 1 feed on the catch tank ?? is there 2 filters on it ??? if so plum it in that feed its the positive crankcase ventilation valve ( gets rid of back pressure do not block it ) Edited May 7, 2016 by 5e colin Quote
Cyanidesid Posted May 7, 2016 Author Posted May 7, 2016 leave as is for now as you seem to have only 1 feed on the catch tank ?? is there 2 filters on it ??? if so plum it in that feed its the positive crankcase ventilation valve ( gets rid of back pressure do not block it )there are two air filters on the catch tank so I will take one off and put the pipe to there Quote
5e colin Posted May 7, 2016 Posted May 7, 2016 yes and block the air nipple /feed on the intake manifold Quote
