As above, mine has a hairline split and won't stop leaking.
Will probably need posting or pick up locally, I'm in North London.
Thanks, Kyle.
It's not the rubber hose I'm looking for, the actual feed/return pipe, it only split because u didn't remove it when taking the manifold off, must have kinked and cracked it.
Yeah you can get a braided oil feed upgrade for the ct9 in stock place. The likes of Race tech, zisco used to make them up for around £40. Then you have some flex when moving it around, plus the oem feed is around 20 years old.
The race tech ones are 60 quid!
I've got a standard one somewhere if you want it mate? I don't get time to get to the post office though
Sent from my iPhone using Tapatalk
