glanza179 Posted January 24, 2006 Posted January 24, 2006 i would like a set of TRD coilovers on my Seo i know it shares alot of simularities with the starlet is the supension set up the same??Jim Quote
scutch0 Posted January 24, 2006 Posted January 24, 2006 i assume so jim... i'd say the fronts will probably defo be the same, not too sure about the rears though.Rich. Quote
glanza179 Posted January 24, 2006 Author Posted January 24, 2006 cheers rich ill keep lookin into it but i need somethin to lift the ride height a bit the front end at the moment when sat on the flat is no more than 50mm off the deckJim Quote
starletboy Posted January 25, 2006 Posted January 25, 2006 im pretty sure they are the same i have changed a few on seos and they look near enough identical to starlet ones but never had the two side by side to be sure Quote
