ReeceGolliker Posted July 14, 2016 Posted July 14, 2016 This has been winding me up for a year now. I've got a 96 spec ignition barrel on a 98 spec rack. Everything else on the car is 98 spec. I can't get the steering wheel surround to fit with the ignition barel. Do I need a 96 spec surround? And will that bolt up and line up with everything else? Cheers. Quote
SpikeyJp_68 Posted July 14, 2016 Posted July 14, 2016 Yes the column surrounds are different so if it's a 98 you'll need a 98 column surround, 96 you'll need a 96 column surround Quote
