Chrscrr5 Posted August 12, 2016 Posted August 12, 2016 Need help as im installing lowering springs. I cant actually undo top of suspension unit, ive done frint but the rear has different nut on top. Whole shock spins when try to undo it any heko please asap Quote
Starlet__SR Posted August 12, 2016 Posted August 12, 2016 Should be able to get an adjustable on the top of the shaft. If not you need to airgun them off Quote
Chrscrr5 Posted August 12, 2016 Author Posted August 12, 2016 I have tried with an adjustable and it started to chew up, i dont have an airgun 😔 I have tried with an adjustable and it started to chew up, i dont have an airgun 😔 Quote
Starlet__SR Posted August 12, 2016 Posted August 12, 2016 Only other option is mole grips. But its a crude approach. Where are you based? Quote
Chrscrr5 Posted August 22, 2016 Author Posted August 22, 2016 I tried mole grips too, ended up just buying new shocks! So all sorted now, cheers! Quote
Pete_A Posted August 22, 2016 Posted August 22, 2016 Welcome, what an expensive solution! Invest in a nut splitter for next time Quote
