Glanza gearbox needed asap!
I've got one that is in good condition but it's not an LSD box, it needs a new drive shaft seal but I've got a brand new Toyota one that you can have with it. I've just removed from my car and put the N/A box back as I'm about to sell the car. I'm based in Barnsley in South Yorkshire. I'm looking for £150.
i have an OEM LSD box, longer shaft, sandwich plate, polybushed rear mount , basically a full bolt on kit ready to be used, also have a 6 paddle clutch , lightened flywheel, if you wanted to go the whole hog lol
im based in Essex and box has been inspected and is in perfect condition
Sounds nice mate, Just a touch too late tho 😞. Picked up a box on Wednesday and im going to fit the lsd i purchased from my guy^^^^!
Still how much you wanting for everything needed to swap from standard diff to your lsd kit with the bracket and shorter shaft?
Also what clutch is it you have?
