Jam ecu has code 14 - jam ecu has green sticker and black jam label and has code 10040 and standard ecu has code 10100 and is black sticker
Also the Pin out you supplied is for the ep91 mine is the ep82 sorry
look at the diagrams properly....they are ep82 ecus with two plugs/connectors---as per your part numbers supplied
and they are differences in the pins
ep91 ecus have 3 plugs/connectors...the only ep82 ecu with 3 connectors is the automatic
"ep91.com" is an old website ---maybe the posted is just crediting where he/she got the original information from
Edited by gorganl2000
All pins match apart from number one
based on a quick look...there are a few differences on connector 2
on connector 1...the 1st pin is different/missing
check both connectors/pinouts properly :thumbsup:
All pins match , plug standard ecu with black sticker coded 10100 in and no codes , plug jam ecu with green sticker coded 10040 and all is fine until I start it and. Instantly code 14 appears any help from any one much appreciated
from looking at the diagrams, all the pins do not match on these two ecus
Connector 1 on JAM ecu (89661-10040 according to what you stated above)
pin 1 is blank... where as its IPV (vacuum switching valve) on the stock ecu
Connector 2 on JAM ecu
pin 7 BC boost control....whereas it is TE2 check connector on stock ecu
pin 8 T....whereas it is TE1 check connector on stock ecu
pin 12 is blank...whereas it is AC1 A/c switch signal system (12v to aircon computer) on stock ecu
pin 15 is AC1...whereas it is BC boost control on stock ecu
