turboing a n/a
Loom
Ecu
Inlet manifold and throttle body
Sump
Manifold
Standard cat
Top mount intercooler
Fuel rail
Injectors
Ct9 hot pipe
Fuel pressure regulator
Thermostat housing
Clocks
Stalks
clutch
Flyweel
Oil fiter housing
Rocker cover
Actuator
Water lines
Oil lines
Distributer
Map sensor
Turbo
New gaskets
All parts need to be from a turbo car obviously, i have got most of those parts and i have spent near £600 so far but got most cheap if im honest, buy the time i have done i think more towards £900 with upgraded brakes (going glanza v fronts/bigger discs)
Best of doing some research on here first.
