Anyone help me? I've got some glanza v clocks to fit into my N/A how do i go about wiring them up what plugs do i need to switch around etc. Also is there a way i could get the shift lights to work through the gear box or what not without boost solenoid with it being N/A?
They're not shift lightw they're boost lights so no it won't work.
I'm sure there's already some tutorials around for the Glanzz clocks... What I did on mine was get some Starlet CD clocks and install Glanza S dial faces, the Glanza S doesn't have the boost lights so it's better for N/A
You need the pinouts for both and switch the wire around, it's simple mate but takes some time, it also gets frustrating when something is wrong and you can't find what it is
Have you got facebook mate as im on me phone and i think i might have the right diagram for the plugs and what needs changing etc but am on my phone amd cant post a picture here
  • 1 year later...
On 10/31/2016, 7:20:15, EP70-PT said:
I commented on your post on facebook ahah João Campos mate
Help needed how do i get glanza s clocks to work on n/a starlet
