EP70-PT Posted November 18, 2016 Posted November 18, 2016 So, I have a breather filter on my rocker cover, my bonnet scoop is open, could water go through it while driving and into my oil? the filter is thick so I think it would take a while for the water to sip through the filter, anyone thought about this ever or am I just overthinking? aahahah PS: the engine is an FE so the breather is on the top right corner Quote
StuDoc 72 Posted November 18, 2016 Posted November 18, 2016 No the water will go down into your plugs. Breather filter normally releases crank case pressure not vaccum so no sooky. Quote
EP70-PT Posted November 18, 2016 Author Posted November 18, 2016 ahahah, magnecores seal the water pretty well so I'm not worried with the plugs Quote
marki7 Posted November 20, 2016 Posted November 20, 2016 ahahah, magnecores seal the water pretty well so I'm not worried with the plugs Spray the rocker with gt86 water will bead straight off or reverse scoop if running front mount Quote
