Mike2016 Posted November 18, 2016 Posted November 18, 2016 So my car developed a leak in my sun roof which is never good. Anyway so I had the issue of water in my passenger side floor which needed to be dried. After using a towel for a while I decided to use a 12v cigarette lighter powered heater as the cars heaters weren't doing all that much. 15 mins later and the heater has stopped working and after testing with numerous devices and a power probe I can safely say there is now power to the socket. My assumption is a fuse however from what I have read that would stop the clocks radio etc from working and they are all fine. So my question is is it a fuse if so where is it located. Car is a 98 Sr Thanks for any replies in advance Quote
fiddlersport Posted November 21, 2016 Posted November 21, 2016 There are 4 pipes connected to sunroof which all go to loeer sill points in each corner of the carIf any water was to go past the seal on the sunroof then the water can travel down the pipe and out the sillsDouble check your sills are not clogged which will then allow water build up and over spill inside of carYou probably have water on electrical connection on passenger footwell which has caused your problem Quote
Mike2016 Posted November 22, 2016 Author Posted November 22, 2016 Thanks for the reply I was at somewhat of a loss to say the least. I'll have a look at this after work providing its not raining. Quote
