Lew Posted January 20, 2017 Posted January 20, 2017 Right guys have a question that I need help with as I'm worried I might ruin the engine. So basically I have a fcd fitted to my ep91 that was set up by previous owner and its running at 1bar on a ct12. I have just brought a top mount tf035 set up for it and would like to get a dastek unichip all set up on my starlet.Now I'm wondering would it be okay for me to remove the fcd and drive the car to the tuning shop, which is about 25 minutes away from me or would that be a bad idea? As I know it would need all the afr set up again if I remove the fcd.Any advise would be greatly appreciated Quote
patman Posted January 20, 2017 Posted January 20, 2017 Lew just out of curiosity what is the fcd set to and what does your fuel pressure reg read when engine is up to temp, very easy solution to this 👍🏻 Quote
Lew Posted January 21, 2017 Author Posted January 21, 2017 currently rebuilding the head so I will pm you as soon as I get her running again Quote
patman Posted January 21, 2017 Posted January 21, 2017 Ok mate your be fine removing it once you have the info 👍🏻 Quote
