starletezy Posted January 25, 2017 Share Posted January 25, 2017 Hello guys, Quick question on the ct9 actuator there's two vacuum ports when fitting a boost controller where do they all go looks like one will have no were to go?. Thanks Tez Quote Link to post Share on other sites
starletezy Posted January 27, 2017 Author Share Posted January 27, 2017 anyone? Quote Link to post Share on other sites
adzy Posted January 27, 2017 Share Posted January 27, 2017 Pipe from turbo compressor housing to top port of actuator, then t-piece into that pipe and run that into the boost controller solenoid, then the pipe coming out of the solenoid will go to the bottom port Quote Link to post Share on other sites
starletezy Posted January 28, 2017 Author Share Posted January 28, 2017 On 1/27/2017 at 3:34 PM, adzy said: Pipe from turbo compressor housing to top port of actuator, then t-piece into that pipe and run that into the boost controller solenoid, then the pipe coming out of the solenoid will go to the bottom portCheers buddy Quote Link to post Share on other sites
