Madge1980 Posted January 27, 2017 Share Posted January 27, 2017 Good evening guys, I have wired in my Avcr this evening, I used the guide from this forum but have a query. The guide says to connect the purple wire from the avcr into pin no3 of the 26 pin plug, which according to the vehicle ecu manual is "ignition feedback from the ignitor coil"Can anyone confirm if this is correct as I have connected the purple wire into pin no4 on the 26 pin plug, which according to the vehicle ecu manual is "part of the IIA (rpm)" which seemed the correct one to me but the rpm on the avcr display is not reading correctly.Any ideas?? Quote Link to post Share on other sites
Madge1980 Posted February 11, 2017 Author Share Posted February 11, 2017 Just in case anyone else comes across this, just wire it in as the diagram says!! Quote Link to post Share on other sites
