Pete_A Posted January 27, 2017 Posted January 27, 2017 Is it as easy as just remove plastics, key in one turn and press in lil button to slide it out? And do i need the ecu from the matching car/barrel? Quote
Pete_A Posted January 28, 2017 Author Posted January 28, 2017 Come on! someone must know?! i wana get it done today Quote
adzy Posted January 28, 2017 Posted January 28, 2017 Plastics of, then there are 2 bolts with dome heads holding the barrel to the column, you'll need to cut a line into the head of them so you can use a flat screwdriver to take them out. Then you just unplug the barell from the loom. Don't need the key in or matching ecu Quote
