jayc-glanza17 Posted February 20, 2017 Posted February 20, 2017 Has anyone dry sumped their starlet? Quote
gorganl2000 Posted February 21, 2017 Posted February 21, 2017 (edited) i've never heard anyone doing it..only the rare passing discussion...most just improve the baffling in the oem sump or buy an aftermarket baffled sump for track/circuit/sports purposes i'd imagine the costs may outweigh the benefits/logistics for our cars, or else someone would have done it by now but let's hear what the others say,,,you may get lucky Edited February 21, 2017 by gorganl2000 Quote
AdamB Posted February 21, 2017 Posted February 21, 2017 If anyone's done it, it'll be Spuddy or the guys at Zisco I would have thought, but these are all drag motors. It wouldn't be too difficult to fab something up if you know a good fabricator as you can use the air con location for the pump. A sump pan would be rather simple also as it would just be bent at right angles on all 4 sides with a few fittings. If you're worried about oil starvation on track, a cheaper alternative is using an oil accumulator, this will dump a load of oil into the engine during hard cornering to stop it from starving. Quote
jayc-glanza17 Posted February 21, 2017 Author Posted February 21, 2017 Adam ive thought of that the air con pump area is ideal for the dry sump pump.Reason im looking at it is starvation worries me long term. Definately something to look at. zisco did fab up one. Quote
gorganl2000 Posted February 22, 2017 Posted February 22, 2017 drop phil a msg...he did a lot of hillclimb and track...maybe he can give you some pointers as well Quote
TimD Posted February 22, 2017 Posted February 22, 2017 Never had a problem with oil pressure with mine, just a baffled sump. Quote
AdamB Posted February 23, 2017 Posted February 23, 2017 Adam ive thought of that the air con pump area is ideal for the dry sump pump.Reason im looking at it is starvation worries me long term.Definately something to look at.zisco did fab up one. Quote
